Tech: Performance - Snowmobile at Off-Road.com
Snowmobile »
Price and Compare Vehicles:
New, Used, and Powersports    Go button
Tech: Performance
  • Boosted Four-Strokes. The Sled of the Future?
    The MPI kit is very impressive how all the components have been carefully machined to work around the stock machine.
    Snowmobile Tech: Vforce Reeds Install
    Reeds are a one-way valve located downstream from your carbs, mounted between the crankcase and cylinders. The motor pulls the air/fuel mixture from the carbs, through the reeds and into the case.
    Clean Your Snowmobile's Exhaust Valve
    When the motor runs dirty the power valve tends to get covered with carbon deposits and it impedes the valve's ability to slide. When this happens, the valve will "stick" in one position and your sled will either lose low end torque or high end power.
    RacePak Avenger System Installation & Setup
    If you are serious about squeezing top performance out of your snowmobile, then one tool you should have is the RacePak Avenger system by Exhaust Gas Technologies, Inc.
    Snowmobile RAVE Exhaust Maintenance Photo
    Return To RAVE Article - photo gallery
    R.A.V.E. Maintenance Photo
    Installing Bender's VIP Pipe
    The 2002 Yamaha Viper is an amazing sled, no one will argue that fact. BUT, all good things can be made better with a bit of good ole hard work. Bender has spent the past year doing just that, with a whole lot of research and development and an awful lot of hours spent on the dyno.
Untitled Document
Need Gas Mileage & Power?-
Off-Road Videos -
ATV Reviews -
In the Business of Off-Road?-
If you work in the off-road industry, you need Off-Road Business! Our magazine, eNewsletter, and website give you the latest industry news, new product reviews, and business tools and services you need to succeed! Check out OffRoadBusinessMag.com!
Enewsletters
Stay on Top of All the Action:
Sign up for Off-Road.com's Enewsletters
Click here
